1 - 11 of 11 Posts
I just got done driving my 91 volvo 240 from Central Florida to West Texas... At an Alabama Gas station I attempted to open the hood by pulling the latch and the cable snapped off so now the handle just hangs loose and the hood can't be opened.. I ran inside and bought a pair of needle nose pliers and tried to pull it out to pop the hood (the first time I was successfull, I haven't been since) and it's leaking a bit of oil and is ready for an oil change..<p>I've heard everything from getting it from underneath to busting my grill (which I objected to) <p>anyone had a similar problem or can offer advice to get this hood up so I can check the oil and tranny fluid?<br>
Discussion Starter · #2 ·
Re: [91-240] getting hood up w/ broken latch? (obdh)
got the hood up, but it was a pain in the ass... I crawled underneath the front and managed to slide my hand up to where the cable was mounted underneath and flipped the latch... I tried for about 30min then crawled out and was messing with something else and pushed on the hood and it was opened...<p>is it easy to just replace the whole cable? it's missing a few inches
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>obdh</b> »</i></TD></TR><TR><TD CLASS="quote">got the hood up, but it was a pain in the ass... I crawled underneath the front and managed to slide my hand up to where the cable was mounted underneath and flipped the latch... I tried for about 30min then crawled out and was messing with something else and pushed on the hood and it was opened...<br></TD></TR></TABLE><p>that's pretty much the only way if you want to preserve your grille.<br><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote »</i></TD></TR><TR><TD CLASS="quote"><br>is it easy to just replace the whole cable? it's missing a few inches</TD></TR></TABLE><p>yes, very straightforward.
Re: [91-240] getting hood up w/ broken latch? (rs4-380)
do you know offhand what size the oil drain plug bolt is... All my tools got stolen so until I can buy more next week I need to just buy one, the right one! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
uh, i want to say 25mm???'<p><br>just buy a crescent wrench and you'll be all set.
I did end up getting a crescent wrench in the end... more useful than a big one size $15 wrench
Re: (DVolvoguy777)
Yeah, I managed to not bust my knuckles while removing the oil drain plug, but while putting the oil filter on (as usual) I scratched my hands all to hell.... guess that exhaust manifold has some sharp edges somewhere I can't see
Re: (obdh)
Mechanix (sp?) makes some wonderful gloves that prevent this, but they are a bit pricey, something 25 bucks, but think about how much pain they will save you from. anyway, fix the hood! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0">
Re: (Camyman)
The typical use of a box wrench prevents cuts and scrapes etc. Fit alls are grate but hard on the hands. <p>I am still kickin around tryin to remember what size that bloody bolt is....( on the oil pan) I had SAE Volvo's in the past. My 850 is my first metric Volvo.<p><br><IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
Re: (DVolvoguy777)
Leave the grille out, and you can open the hood easily. BTDT.<p>Drain plug is 25mm. IPD magnetic is 1" (=25.4mm). Oil temp sender drain plug is 22mm.
1 - 11 of 11 Posts
