I gave my daughter a 1990 240 with 190k on it. After approx. 5k the overdrive failed. I replaced the trans. with another and the overdrive failed after 2k. The second trans. had 180k on it. Both trans. shifted properly in all 3 gears, just would not shift into overdrive. Any thoughts on the possible problem? Were there any problems associated with the overdrive on these trans.?
Re: '90 240 overdrive (marcrex)
Welcome back to Swedespeed, Mark.<p>Did you ever get the back seat out of the 245?...<p><A HREF="http://forums.swedespeed.com/zerothread?id=106471" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=106471</A><p>On the OD - check the solenoid, relays, fuse and all wires, electrical junctions and grounds.<p>George Dill<br>
