I promise I searched, but I cannot find a 855 T-5R specific list. (Auto Preferably)
I am wondering does someone have a similar list per below (from page https://forums.swedespeed.com/showthread.php?505922-Volvo-850R-suspension)
but for the 855 T-5R (auto) suspension and steering refresh (as in throw everything away and replace with new OEM item)?
Thank you in advance.
(List from sventastic)
Front suspension:
Strut: Sachs (PN: 9173850) $80 https://www.fcpeuro.com/products/vol...70-v70-553-058
Spring: Still need to find a source
Strut mount bearing: INA (PN 3546189) $50 https://www.fcpeuro.com/products/vol...0-s80-87-424-a
Strut mount cap: NPN (PN 30647969) $5 https://www.fcpeuro.com/products/vol...-s60-xc70-xc90
Strut mount spring seat: Sachs (PN 8646713) $20 https://www.fcpeuro.com/products/vol...0-s60-s80-xc70
Strut bellow: Febi (PN 9140068) $3 https://www.fcpeuro.com/products/vol...w-febi-9140068
Bump stop: Febi (PN 9140067) $7 https://www.fcpeuro.com/products/vol...bumper-9140067
Control arm: $96/each Lemforder (Left and right) https://www.fcpeuro.com/products/vol...kit-p80cakt2p2
Sway bar link: Lemforder (PN 31212730) $17 https://www.fcpeuro.com/products/vol...-s70-v70-850-2
TOTAL: $556USD/$710CAD + cost of springs + hardware if you want
Rear suspension
Nivomat shock: Sachs (PN 9140391) $278 http://www.rockauto.com/en/moreinfo....sn=418&jsn=418
I believe this is the same but much cheaper: $151 https://www.tascaparts.com/oem-parts/volvo-strut-271809
Shock mount: MTC Parts (PN 9140847) $25 https://www.fcpeuro.com/products/vol...70-850-9140847
Bump stop: Febi (9140067) $7 https://www.fcpeuro.com/products/vol...bumper-9140067
Rear spring: Also not sure on the part number for this
Trailing arm link: Volvo (PN 3516122) $207 https://www.fcpeuro.com/products/vol...-850-3516122oe
Trailing arm bushing: Volvo (PN 9181013) $67 https://www.fcpeuro.com/products/vol...181013-9181014
that list looks pretty decent. You want to use VIDA to confirm the PNs. There are different versions of Nivomats. There are also different versions of the strut mounts for Nivomats vs regular rear shocks.
You want the sport/lowered Nivomats and yellow marked springs all around.
Okay, I will double check the PN. But generally 850 T-5R and 850R uses the same suspension minus the Nivomats? Thanks
T-5R can be weird since things were still being developed early in the production. My VIN doesn't give the same suspension as 850R but maybe that's just because mine's preproduction and therefore very weird. I've never run another T-5R estate VIN to check.
