Parts prepare for Turbo swap
-Turbo TD04HL-16T / 15G Both 16T and 15G turbo will work. You can get one used on ebay. Or you can buy brand new one by Kinugawa or Mamba. They both provide really good CHRA or whole turbo kit with accessories. The exhaust housing port to CHRA on 16T and 15G are same. Early 16T and 15G have same coolant port(in and out on opposite side), it can be a direct swap. The later 16T has angle flange on exhaust downpipe. The even later 16T CHRA has different coolant port(in and out on same side).
I got a used later 16T from ebay
-Oil and coolant lines for later 16T. You need the coolant in and out line. Oil in line. No need oil reture line. You can grab these parts from any 2000s 2.5T engine cars.
Parts prepare for Manual swap
Used Parts
-Transmission I got a transmission from a junk 1999 C70 T5
Pedals I got one from a junk 850 manual. You can modify one from x70 to 850.
Shifter assembly 850 and x70 are exact same. I got each one from 850 manual and C70 T5.
Shifter cables 850 and x70 are exact same. I got used one from C70T5
Reverse light switch It should be attached to the transmission
Clutch master cylinder fluid feed hose PN 9157190. This part is discontinued. You need to get one from junk yard.
New Parts
Flywheel I recommend a new one. Less problem in future. The OEM turbo single mass flywheel is discontinued PN 9454774. You have two option, 1. the non turbo single mass flywheel PN 9454772, These is no difference to the turbo one and you can still buy genuine Volvo part for this one. 2. Aftermarket tubo single mass flywheel from SPEC PN SO13S. This one is 1.3lb lighter than OEM. It comes with pressure plate bolts. I got the SPEC one because it is cheaper than the genuine non turbo SMF.
-850R clutch PN 272218. It can use one both SMF and DMF.
Clutch master cylinder PN 9163880. It is pain in the butt to remove and install. Just buy a new one then less headache in future.
Rear crankshaft seal/rear main seal PN 9458178.
Transmission input shaft seal PN 1381798. 41mm OD
Axle seals PN 6843481. Need 2.
Flywheel bolts PN 9454743. Need 10
Pressure plate bolts PN 959219. Need 6. If you buy the SPEC flywheel then you don't need these.
Transmission fluid PN 31280771. Need 3. This is genuine Volvo manual transmission oil.
Transmission with internal slave cylinder
Clutch slave cylinder PN 31259445.
Clutch hydraulic hose PN 9181324
Other parts
-3502507 “clip”. 4 required, these are used at both the shifter assembly and at the transmission.
-989037 “lock brace” 2 red’d, these are the clips that hold the shifter cables where they attach to the shifter mechanisms on the transmission.
-986417 “washer” 2 req’d, these are used with the above clips.
Price for all new parts from www.volvopartscounter.com
Item | Part # | Quantity | Amount | Status | ETA |
Master Cylinder | 9181217 | 1 | $166.27 | - | |
Clutch Kit | 272218 | 1 | $230.64 | - | |
Slave Cylinder | 31259445 | 1 | $168.77 | - | |
Hydraulic Lines | 9181324 | 1 | $91.54 | - | |
Manual Transmission Input Shaft Seal | 1381798 | 1 | $4.86 | - | |
Manual Transmission Output Shaft Seal | 6843481 | 2 | $20.10 | - | |
Engine Crankshaft Seal | 9458178 | 1 | $25.00 | - | |
Clip | 3502507 | 4 | $10.36 | - | |
Support Cylinder Retainer Clip | 989037 | 2 | $3.42 | - | |
Valance Panel Washer | 986417 | 2 | $3.42 | - | |
Clutch Flywheel Bolt | 9454743 | 10 | $30.40 | - | |
Transmission Oil | 31280771 | 3 | $45.24 | - | |
Subtotal
$800.02
Shipping (UPS Ground)
$40.58
Total
$840.60
Price for parts from Ebay
SPEC SO13S Steel Flywheel
ORDER TOTAL US $454.74
High Pressure Turbo TD04HL-16T 8601691
ORDER TOTALUS $254.39
