Help! I need to replace the shocks in my wagon. I can't seem to find a way to remove the "floor" above the shock mountings. I can't find any bolts or screws to remove. any tips? thanks in advance --rodsob
You said wagon, its actually reall easy. The panels are wood, covered in carpet in the back. They all are snapped into place with clips, no screws. its really easy to get them out, you just pull. A little careful prying may be in order though, not sure how stuck down your are. Basicly dont worry about breaking anything because of some screw you forgot. No screws hold those panels in, just these metal pressure clip things. Good luck
True for 3 of the panels, but the 4th and the one you need off the most is held on with 4 10mm bolts, after removal of the side panels you will see them, after these ar out pull the floor section towards you as you stand at the rear of the car as it has tabs that slide into place.
