I was wondering is there a difference in the engines in the turbo models? Or were all the 93-97 turbo engines the same?
google is your friend, try volvo 850wiki
No. they were not. difference in engine displacement, whether or not they were HPT or LPT, stroke, bore... alt of differences. only thing in commo. is the 20valve head, all
turbos came with a 20valve head. anything specific you want to know? I can take you through all of them.
Turbo is a 2.3L engine and the NA is 2.4L. The turbo'd engine I believe is also lower compression and has sodium filled valves for heat.
you are forgetting the 2.0L LPT 175HP, the 2.0 T5 HPT 211HP, and the 2.5 LPT 193HP mostly found in V70s.
