is the rear seal wearing out or is there a build up of pressure in the crank case because of a clogged vent issue?
Re: 850 rear main oil leak (bmitten)
A clogged breather box is one of the leading causes of a rear main seal gone bad. (Oil has to go somewhere) <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0"> <br>When, not if you replace the seal, clean or replace the breather box at the same time.<br>If it's leaking it's done, need to replace, you cannot "save it"<br>
Re: 850 rear main oil leak (JRL)
You really should also replace all the related hoses going to and from that breather box, as mine were not in the best shape. And my beather box wasnt even clogged! <br>Here's a link to FCPGrotons page that has the oil trap (breather box) for non turbos:<br> <A HREF="http://www.fcpgroton.com/volvo850oiltrap.htm" TARGET="_blank">NonTurbo Oil Trap</A> <br>And here's the link if you have a turbo engine:<br> <A HREF="http://www.fcpgroton.com/volvo850oiltrapturbo.htm" TARGET="_blank">Turbo Oil Trap</A>
Yes there is. Here is a link with pix and instructions:<p><A HREF="http://volvospeed.com/vs_forum/index.php?showtopic=29650" TARGET="_blank">http://volvospeed.com/vs_forum...29650</A>
