1 - 2 of 2 Posts
I am inheriting this beauty that hasn't been running for over a year. The last time it was running it had just gone through an emissions inspection and passed with the use of ethylene I believe. Shortly thereafter it stopped running. I think I have narrowed it down to a fuel problem because it will turn over and start, RPM's jump to 2K for maybe a second, then it dies. Pressing on the accelerator has no effect.
When I turn the ignition key, I can hear the hum of the fuel pump most times. But when I do, it seems to hum indefinitely. Is it supposed to prime and then shut off?
Where should I begin? I have seen somewhat similar posts that talk about the screen on the in-tank fuel pump being clogged. I believe the fuel filter under the hood is new. Does it sound like a flow or pressure problem? Too early to tell?
Thank you for your time
Re: '84 GLT starts but will not idle (DirkSteele)
Welcome to Swedespeed, Dirk.
For sure sounds like a fuel problem.
If the car has a fuel pump relay it could be faulty but from your description of the problem a more likely possibility could be a faulty fuel pump or fuel pressure regulator.
If the fuel system is full of gunk from more than a year of no-run status then a full clean-up is in order.
Carefully check to confirm fuel at the injectors.
George Dill
1 - 2 of 2 Posts
