1 - 10 of 10 Posts
Want to convert your pre ‘90’s 700 series Volvo to manual transmission? Now’s your chance to ditch that slush box and enjoy shifting for yourself.<P>I am selling a single 700 series transmission swap kit. This kit includes a used M46, Clutch, Flywheel & Pressure Plate, Crossmember, front ½ of the Driveshaft, Master and Slave Cylinders, and associated Hydraulic Lines, Shift Lever, Interior Trim (black plastic) & Shift Boot (black rubber), Clutch & Brake Pedals, as well as the pedal assemblies. The OD wiring harness is also included, however the OD relay is not. If you have an AW71 (Automatic with hydro/electric OD) then you are able to re-use that relay. ’90 and later models will require a hall effect sensor equipped flywheel.<P>All parts were pulled from a running but wrecked 740tic, and are known to be in operating condition. I pieced this kit together only to have the buyer back out at the last minute. The kit is located in Napa, I will deliver within 50 miles if you cover my gas. Price is $700 firm, but will sell to highest bidder if demand is great. I will knock off $50 in exchange for a good AW71.<P>A digital picture of the kit is available upon request. I need to sell this quickly as money is getting tight, but am unwilling to take a loss.<P>Paul Demeo completed the conversion and detailed how he did in this web article:<BR><A HREF="http://www.geocities.com/p_demeo_2000/conversion.html" TARGET=_blank>http://www.geocities.com/p_demeo_2000/conversion.html</A><P>Please respond via EMAIL.<P>-Isaiah<BR>[email protected]
The bellhousing is the same, but the shift lever location is different. As well, the driveshaft coupling is different. 740's use a rubber doughnut looking bushing with six rather large bolts to connect the transmission to the first half of the driveshaft, where as 240's use dual metal flanges with four bolts.<P>The crossmember is also different.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by [email protected]:<BR>I wonder how tough it'd be to put one of these manual trannys in a 240?B]<HR></BLOCKQUOTE><BR>Why would you want to? It would be much better to get the M90. The M46 isn't to strong.<P>
M90's are great.<P>IF:<BR>You have about $1,000 to spend on the transmission alone.<BR>You dont mind importing replacement parts. (no way are you going to be able to get a set of seals or syncros from your local volvo dealer)<P>If you have money to burn, go for an M90.<P>M46's are good to over 250ft-lbs of torque if treated with respect. If you abuse the transmission it will die, no matter what torque you run.<P>George, if you want to convert your 240 to a manual transmission I could set up a similar kit, except using a 240 as the donor.
I decided to put this in an ebay auction. It starts at $500. Good luck to all that bid.<P><A HREF="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1853386135" TARGET=_blank>http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1853386135</A>
1 - 10 of 10 Posts
