Simple questions:
How much brake fluid do I need for a flush/fill for single circuit brakes?
How much to do the same on a hydraulic clutch?
Cheers,
Not very much, I just bleed a completely new dry system (all lines, calipers, wheel cylinders) and I think I used less then 16ozs and that was even probably overkill because I bleed every corner 3 times.
Thanks... didn't think it could be all that much, but didn't want to run out in the middle of the work.
