I saw this ad for 6000k Xenons on Craigs List (Los Angeles). Is this a good deal or is there somewhere or someone that has it less expensive.<p>Also, are these truly easy to install as the description says they are..What 30 minutes of labor to install?<p>Reply to: [email protected]<br>Date: 2006-08-09, 9:01AM PDT<p><br>BRAND NEW HALO HID XENON KIT 6000k, 8000k 10000k 12000k Plug&Play comes in H1, H3 H4, H7 H8 H11 H13 9003 9004 9005 9006 9007 9008 Made in Japan $230 [email protected] AIM: autolightings <br>626 616-0497 <br>Xenon-Halo HID Conversion Kit is a True Plug-N-Play Kit. Our conversion kits fit into your headlight housing perfectly. No modification or retrofitting is required. No need to cut your stock headlight wiring. Our kits is made so that it all Plug-N-Play. Just connect the wiring harness from the stock headlight wiring to the ballast. From the ballast, connect the wiring harness from the ballast to the HID Bulbs. Put the HID Bulb back into your headlight housing and your done. Detailed instructions will be included in the kit. Xenon-Halo HID Conversion Kit # 1 year no hassle warranty on ballast and bulbs through us, if it ever goes out, send it back and we will replace it immediately. # Waterproof and shockproof on bulbs and ballast # Waterproof connectors and grommets # HID bulbs is only 35 Watts compare to stock Halogen 55 Watts # HID bulb is expected to last 2500 to 3000 hours (5 years) compare to halogen, which is 500 hours (1 year) # Lighting output is 3 times brighter than regular halogen bulbs # Ballast has built in igniter, HID Kits with separate igniters are prone to burn out. # Ballast has shut off mode, to prevent a fire or damages if something went wrong # ISO9001 Certification and European E-Mark for 100% guaranteed product quality # This is the real HID Xenon kit, not those $20 Xenon gas charged bulbs that burn out in 3 months # 3,000K, 5,000K, 6,000K, 8,000K, 10,000K and 12,000K kits are also available. # Please email us if you have any questions on the Hid Kit or need any technical information. <br>
we sells them <A HREF="http://www.xenon-shop.com" TARGET="_blank">http://www.xenon-shop.com</A> and also we work with a lot of forums around the world. Best quality, best prices
<--- does h/w.<p><A HREF="http://www.xenon-shop.com/english/helios6000K.htm" TARGET="_blank">http://www.xenon-shop.com/english/helios6000K.htm</A>
Re: (dkiburbank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>dkiburbank</b> »</i></TD></TR><TR><TD CLASS="quote">What is typical pricing and is installation easy?</TD></TR></TABLE><p>very easy to install, the price is $260 shipped
