1 - 9 of 9 Posts
OK lads, looks like there's been plenty on this in the past.<p>Simple question, will a 55W kit plug in and work without popping the blown bulb light and <br>will it not cause any smoke to come up from anything when I turn em on? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0">
will work perfectly fine and it should ..... not trip the bulb out light . <p>I know it will work but the bulb out light is hit or miss between cars.
hit or miss exactly.<br>Got a 35W HID with the message supressor adapter... Got some random "bulb failure" messages but nothing major... just have to re-start the car if it appears. Other than that, some bulb warning message flashes...<br>For heat, the 35W does not heat up the lense that it becomes noticeable.<br>Would be really interested in knowing if a 55W kit would resolve this minor issue....<br>For sure a 55W would be brighter (too bright?).
Re: (harleyvh)
What are you guys using for housings after you install the kits? Are you retrofitting a projector into the current housing?<br>
nah I went with 05+ headlights and it has a very good cut off not projector cut off but pretty damn close
Re: (harleyvh)
no changes to the headlight itself planned as yet.<br>if there is a cutoff problem, i'll roll the headlight aiming wheel down!!!<br>04 factory headlights appear to use the same reflector anyway just different bulb mount for the D2S/D2R OEM HID bulbs and a little plastic cap on the end.<p>cant hurt to give it a run, cost less than $100 AUD delivered from Hong Kong.<br>(yet to arrive from last week but will be soon)<p>karl
Re: (LPG Karl)
done, waiting for it to get dark now..........<p>piece of cake, mounted one in the ECU box the other just behind the headlight, almost looks like it was meant to be there.<p>Thinking this is gonna get expensive, 2x T5 volvos 3kits for hi-low and fog each.........<p>All of a sudden I'm out 6 kits!!!!<p>Karl
1 - 9 of 9 Posts
