1 - 8 of 8 Posts
Sorry for the stupic Q. I've seen both. My owners manual says 6.1 but I just read in the tranny fluid thread that 6.1 is for turbo NON-R. Which is it?<br>Thanks
Re: 5.5 wts or 6.1 for 2004 R??? (1080Rider)
follow your manual. you can't go wrong
5.5 and check the stick after that.<br>R is using an oil sensor so it has a bit less space in the crank pan.
Re: 5.5 wts or 6.1 for 2004 R??? (flyfishing3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>flyfishing3</b> »</i></TD></TR><TR><TD CLASS="quote">had an oil change this morning. work order says they used 6.5 quarts.hhhhmmmm.</TD></TR></TABLE><p>Sounds like you'll be pulling a dipstick tonight and perhaps raising some hell tomorrow. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/eek.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>flyfishing3</b> »</i></TD></TR><TR><TD CLASS="quote">had an oil change this morning. work order says they used 6.5 quarts.hhhhmmmm.<p>mike</TD></TR></TABLE><p>this was a dealer or indy mechanic?
Re: 5.5 wts or 6.1 for 2004 R??? (Johann)
Just put in 6 quarts. <p>Even if it's overfilled by a half quart, which it probably won't be , it will be okay. <p>The trans take 8 quarts and the drain dumps out about 3.5 quarts from what I have found. TC hold the other 3309 fluid.
Re: 5.5 wts or 6.1 for 2004 R??? (fredmc)
R engine oil cap is 5.5 l (5.8 qts) per Volvo ... I put in 5 on a change, then run it, then top off...<br>
1 - 8 of 8 Posts
