1 - 20 of 51 Posts
There has been a lot of talk regarding people's dislike of the R's performance in high performance/autocross conditions. Much of the poor performance can be attributed to the 4C system adjusting the damping rates on each shock independantly, based upon body roll and pitch fore/aft. This results in unpredictable handling, and probably contributes a great deal to the infamous "rear end hop."
From what I can tell, 4C utilizes three accelerometers: 1) detects forward/rearward acceleration, 2) detects horizontal acceleration, 3) detects vertical acceleration.
So I'd like to pose a couple of questions for those that have experimented with disconnecting the rear accelerometer: does doing so eliminate the 4C chassis setting damping rates (i.e. comfort, sport, and advanced)?
If not, has anyone tried disconnecting all three accelerometers to see what happens?
If so, then has anyone tried utilizing a capacitor to normalize the 4C's readings of the accelerometer? In other words, the 4C reads that the accelerometer is reporting steady-state inputs, no variations.
I think we can all agree that we like the ability to adjust damping rates at the push of a button, but dislike the fact that the vehicle is unpredictable due to the 4C adjusting rates independantly. It would be nice to come to some amiable solution.
Re: 4C and variable damping (JimLill)
So what tricks could be played to elicit predictable handling?
Re: 4C and variable damping (R Salesman)
Anyone attempting this stuff needs to look at and feel very comfortable with the Signal Levels defined in VADIS and the wiring diagrams in the Wiring Diagram Manual. I'd also suggest looking into the accelerometer chip Spec Sheets such as:
http://www.analog.com/en/prod/....html
Not stuff for the faint-harted or fool-hardy....
A review of the R Tech notes (sometimes seen as R5.pdf on the net) would be in order too.
Quote, originally posted by R Salesman »
Disconnecting any of the sensors results in an error condition, and it completely disables 4C, resulting in a "sport-like" mode but without the shocks adjusting the valves.
Yes, with a simple resistor network, but only on the rear sensor (easiest one to get to). I've been tempted to do it to all the sensors, but there's too many and not all are as easy to get to as the one in the trunk. Doing just the one in the trunk results in a very "floaty" feeling, and makes the rear-end hop actually worse. My conclusion is that it is one of the sensors in the front that results in a change in dampening in the rear resulting in the hop.
Mgotts and I pulled the fuses years ago and there are many (older, archived) threads on this.
Disconnected fuses, the R rolls a lot in corners becuse of their factory VERY soft springs.
With lowering (read, STIFFER) springs and the 4C disconnected the car (& wagon) fell pretty good, very stable and very predictable as it does the same thing (suspension wise) every time. Actually with lowering springs (anyones) the springs and the shocks actually are a pretty good match. Remember the shocks default to somewhere in the "stiffer sport" mode
No hop whatsoever. I don't know what you're doing as it does NOT have a floaty feeling at all, (just the roll in the corners but a good feel to it). Just pull the 4C fuse
I haven't removed my (4C) fuse in a long time, it's time to do this again and compare once more as I totally forget how it felt and have become complaisant about the R lately
PULL THAT FUSE BOY!!
Re: 4C and variable damping (JRL)
I ran Nurburgring with stock springs and 4C fuse pulled since system was generating error code and really bad hopping.
Almost got motion sick roll was so bad.
Be interesting to see how it reacts with TME springs and fuse pulled. Although, it does great on the ring in advanced, so I doubt I'll bother.
Re: 4C and variable damping (djeuch)
Quote, originally posted by djeuch »
Actually, it would be interesting to "fake" the signal there... if I knew where "there" was!!!
And fake it with WHAT?
Ask Mgotts, he's familiar with the system
That's why I suggest the WD book is needed.
Re: 4C and variable damping ("R" Kelly)
Don't the sensors/accelerameters work in conjunction with the AWD system, so if you disable them are you stuck with the 90/10 split?
Quote, originally posted by "R" Kelly »
Since you normally only use advanced to do autocrossing or high speed driving (as R Kelly mentioned) I'm having a hard time understanding the complaints with 4C. I thought it was in comfort mode that most people experienced "the hop"?
I've tried disconnecting the rear accelerometer, it did eliminate 4C functionality. The ride was stiffer than sport, not as stiff as advanced. I'm not an electronics guy at all, so I haven't messed with any sort of switches/capitors like Mgotts has.
According to the 4C pdf I just posted in the '05 to '06 thread, the steady state output of the accelerometers is 2V with the signal encoded as fluctuations around that voltage. So theoretically, you could just replace the accelerometer signal with a steady state voltage source pegged to 2V and it would be like it wasn't moving at all.
I'm not sure the computer would like it though.
For reference: http://rapidshare.de/files/177....html
Re: 4C and variable damping (partridge)
Quote, originally posted by partridge »
I think the ideal would be to combine this with, as JimLill suggested, driving the shocks with a constant PWM signal. I'd like constant, adjustable damping values, ie. like having a rheostat on the dash to change the shocks at will (maybe two, one for the front and another for the back). Feed the computer constant, phony sensor values so that it doesn't error and feed the shocks a different set that you manually control.
Not sure what would happen if the computer puked on the static values (after all, it might wonder what is up since it also senses steering input, throttle, braking, etc). Maybe it wouldn't matter, except that you'd have to put up with the error messages on the dash readout.
These are poor-man solutions, working to trick the black box from the outside. The ideal, of course, would be the ability to reprogram the SUM itself.
Re: 4C and variable damping (kenschel)
Quote, originally posted by kenschel »
My solution is pretty simple, actually, and involves splicing a remote relay switch inline with the signal wire on the accelerometer in the trunk. The relay is controlled by radio signal via a button on a small garage-door-opener type keychain fob.
The fob is roughly round and about 1.5-in in diameter. It's made from smooth black plastic with two blue buttons that match the interior theme of the R nicely. I mounted this with double-sided tape in the empty space along the row of buttons behind the shifter. It looks perfectly at home there, and nobody has ever even commented on its presence.
The relay switch in the trunk is set to be normally closed, so that if you do nothing it completes the signal-wire circuit and the acceleromter works as normal. Pressing the remote control button causes the relay switch to open, cutting the signal from the accelerometer, which trips the 4C into "disabled" or "fail safe" mode. The SUM seems to be programmed to tolerate quite a bit of noise and/or interruption in the signal, and it takes four seconds of disconnection before the error is triggered. You must power-cycle the ignition (turn off/turn back on) to re-enable the 4C.
Although I spend most of my time in Sport, I use "disabled" mode frequently -- at least half a dozen times a week. It is ideal for hauling the family around town in urban traffic over lousy roads at normal speeds. I used it tonight to take the kids to swim practice. The car responds much more smoothly to all external inputs and feels like it gains 4-in of suspension travel. Obviously it doesn't really gain any travel, but the difference in compliance is quite noticeable. The suspension is, for lack of a better word, "predictable" and completely normal feeling. My wife has used this exclusively the few times she has driven the car.
Oh, and if you have the "thunk in the trunk" sound, that is gone, as is 95%+ of the sidestep.
Disabled Mode is *way* better than Comfort mode on the 4C, which I find to float uncomfortably at freeway speeds while still crashing over sharp bumps. Comfort is completely useless, at least on my car, and "Disabled' has taken its place.
I've written lots of threads about this in the past; they are probably in the archive. I've never taken pictures of the remote relay setup. That's from laziness, not secretiveness. But I've described how it works in detail. I can provide the name of the relay supplier, part numbers and price if anybody is interested.
A steady-state signal. A simple resistor network duplicates the exact electrical characteristics of the accelerometer when not moving. I've already done this.
Re: 4C and variable damping (mgotts)
Quote, originally posted by mgotts »
you are a kind and patient man to explain all this, but see, it's a lost cause as it involves the following concepts: "SPLICE" "CAR" (mine) "ME"
What for, all you have to do is disconnect, the same result will occur
Not exactly... I've done both. Disconnect disables the whole system - you can't change the damping rates when disconnected. When I use the resistor network, 4C remains active from the standpoint of being able to modify the damping rates.
1 - 20 of 51 Posts
