Elevate Wilwood Volvo P1 (C30, S40, V50, C70) Performance Front Brake Calipers: SIX Piston Calipers for 320mm Volvo OEM-compliant Rotors. Brackets, Pads and mounting hardware INCLUDED.
$599 (shipped or pickup in FL)
Bolt-on Big Brake Kit. Used for about 1 year / 4k miles. Selling my Volvo therefore put back the original OEM brakes and selling this Elevate/Wilwood BBK.
Elevate Volvo Performance Front Brake Calipers, Brackets and Pads: Six Piston Calipers for 320mm Volvo Rotors
NOTE: The ELEVATE Front Brake System will fit under most any factory 17" or 18" wheels and most any aftermarket wheel of similar or larger diameter. The Wilwood caliper is very trim and stays within the same fitment window as your stock calipers with 300/320mm rotors.
- Six Piston calipers increase clamping force over single piston factory calipers.
- For use with factory 320mm rotors
- Lightweight calipers reduce unsprung weight by up to 9.5lbs (4.3kg) per side (depending on vehicle original equipment).
- Shorter stopping distances and reduced brake fade.
- Excellent braking modulation.
- Integrates with factory ABS system.
- Bolt-on installation with hand tools-no cutting or drilling required.
