1 - 15 of 15 Posts
Reading through 320mm brake upgrade kit threads for the P80 and realized that there was no consolidated thread anywhere for all the pieces. This is an attempt to change that. If I missed something, please chime in and the sticky top post will be updated. Looks like you can get a kit assembled for about $450 plus tax and shipping where applicable. Not a bad alternative to porsche/brembo kits for a fraction of the cost. You must have 17" wheels to run these. This is not an endorsement for any of these companies or products, just a listing of what you need to add these to your P80 car if you want to go beyond 302mm brakes.
Cross Post link to the thread that started it all:
http://volvospeed.com/vs_forum/topic/154970-my-320mm-bbk-by-volvo/?page=1
Instructions:
http://www.vivaperformance.com/content/pdf/dvs-p80-320mm-brake-conversion.pdf
Adaptor Brackets & Hardware
DVS - Manufacturer
http://www.dvs.net.au/320conv.html
Viva
http://www.vivaperformance.com/320mm-front-brake-upgrade-volvo-850-s-c-v70/
Calipers:
Amazon
http://www.amazon.com/Cardone-19-B3273-Brake-Caliper-Bracket/dp/B007ETC9Y0
http://www.amazon.com/Cardone-19-B3272-Brake-Caliper-Bracket/dp/B007ETC9H2
Ebay
http://www.ebay.com/itm/Cardone-Bra...e:Volvo|Model:V50&hash=item1e9d4cfe81&vxp=mtr
http://www.ebay.com/itm/Cardone-Bra...e:Volvo|Model:V50&hash=item19feb79d00&vxp=mtr
Autoplicity
http://autoplicity.com/3708383-a1-cardone-19-b3272
Rotors:
Meyle
https://www.fcpeuro.com/products/volvo-disc-brake-rotor-s40-v50-c70-40453070
Brembo
https://www.fcpeuro.com/products/volvo-disc-brake-rotor-31329122
Volvo
https://www.fcpeuro.com/products/volvo-disc-brake-rotor-s40-v50-c70-31329122
Pads:
Akebono Ceramics
https://www.fcpeuro.com/products/saab-volvo-disc-brake-pad-set-front-eur915a
Brembo
https://www.fcpeuro.com/products/volvo-disc-brake-pad-front-comfort-320mm-c70-v50-31212184
Bosch
https://www.fcpeuro.com/products/mazda-3-brake-pad-set-front-bp915
Volvo
https://www.fcpeuro.com/products/volvo-disc-brake-pad-s40-c70-v50-30742029
Thanks for putting this info together. Hopefully it'll get pinned.
Nice job, that had to take some time. :thumbup:
Actually took longer to read the threads than collect the info. Which is why I was surprised that there was no consolidated thread anywhere and as a result decided to just assemble the necessary information in our forum.
Great work! I've been reading up on this and considering it; now when I need brakes I have the template!
Thank you
Dan
thanks a lot for this. Just went to do a wheel bearing last night and realized brakes are toasted so i'm ordering up all this stuff now and you made it so much easier by putting this together! this needs to be pinned so it's easier to find then going a few pages back to find.
Going to put this on one of my wagons and the porsche bbk on the other and compare them. Results will be shared
Looks like there's a P2 rotor that's the same size just with a 5mm different offset. But it has the correct center bore.
P2
P1
Since the caliper rides on a slider, 5mm shouldn't make any real difference. Time to find out!
For comparison here's the stock p80 302 rotor specs
And a comparison picture of rotor/caliper size p80 280mm vs p1 320mm
Hmm.
I've never been 100% satisfied with the 280mm brakes on my v70, so this looks intriguing.
I have to do the brakes soon, so maybe I'll do 302's instead?
So, I've read you need either 17" or larger wheels, or 16" perfo's will also work.
Columba's look just like Perfo's. (Not quite sure why they created a new name). Any thoughts on whether this will work with Columba's too?
you want 302s. I beliueve you have columba on your 00? perfo clear 302s, im running them on several t5's with 302mm brakes.
Stumbled upon this thread since I m considering a 320 setup. good to see all info together.
yet, would that p2 320 rotor with 5mm offset work or not? caliper wise and spacer wise? Don't really want to machine rotors.
wheels would be 7x17 satelites or 7,5x17 comets.
No. It’s too thick.
Yeah, that's what I meant. could have sworn I searched for a thread on 302 conversion, but I must have had a typo. I will delete this and post elsewhere.
I don't want to cause confusion in this thread.
The only spot of confusion I am finding, the caliper bracket needs to have the countersunk hole drilled correct? Some say yes some say no.
Discussion Starter · #15 ·
Yes. But as I found out from running this kit it is incredibly sh*t. You will immediately feel the weight in the steering and the braking power drops off quickly as the pads wear into wedges.
1 - 15 of 15 Posts
