1 - 10 of 10 Posts
Discussion Starter #1
Really nice set of 305s from a 2007 T5.
305mm brake brackets are for upgrading base 286mm brakes to T5 brakes.
These larger brakes clear all 16" P2 wheels.
All P2 XC70s, S60 & V70 2.4t & 2.5t came with 286s. Some early S60 awds came with 305s but most didnt. If you're unsure, check with me.
You will need these carriers and 305mm rotors. Line, pad and caliper stay the same.
Part numbers are LH 9209724 RH 9209725 however the brackets are all the same as the carries shows both part numbers on the casting. The overall "system" PN is 8251316.
They were $63 each +$25 core on FCP but are currently backordered with no eta. Ive been told they're discontinued internally at volvo.
$50 plus shipping
Extremely nice looking set!
Interested from North NJ.
Will these fit 2005 XC70 with 16” wheels?
Just will need to buy 305 mm rotors, everything else bolt on?
What’s your opinion on the overall stoppage of the xc90 316mm upgrade vs this 305mm?
Discussion Starter #5
Well more is always better? I have 316/308 but also 17” wheels. These are certainly a solid upgrade over the stock 286s, very noticeable. 316s on the smaller chassis P2s stop near brembo hard. Well, depending on your pad and tire choice, can stop better than an R.
Discussion Starter #6
This set is sold, but I have more. They’re not as pretty as these unfortunately. Investigating powder coating or having them re-zinc coated. What does everyone thing/prefer?
Discussion Starter #7
$40 plus shipping for the remaining sets.
Place in Springfield does cadmium plating . . . just saying. Powder coat cannot take the heat (polyester resin based).
Separately, for aluminium, am looking for someone local that does the Alodine process (there is a new name for it)
PSA for new name for Gary_52 is Garyjack watch out
Discussion Starter #9
Good to know. Thanks
Discussion Starter #10
Couple sets left! Give your swedish sled proper stopping power for the holidays
1 - 10 of 10 Posts
