1 - 12 of 12 Posts
Are there any negatives to adding a 3inch downpipe<br>to a non chipped s70 t-5? I'm assuming there is no extra stress put on any components. Does the freed up dp lessen the stress on the turbo?<br>I currently have a 2.5 exhaust from the cat.<br>Thanks
Re: 3 INCH DP" (mike_c70)
Hi Mike:<br> I'll be taking some new photos when I get my wheels on. I''ll be sure to snap some photos of the dash.
HI Mike:<br>I'm getting some quirky looking 16 inch bbs wheels. You can see a pic of them in one of these threads. <br>
Re: 3 INCH DP" (volvos70turbo)
By the way, does any one know what the adverse effects are for running rich? (I will run rich by upgrading the dp to 3" w/out an ecu upgrade)<br>Thanks
Have you decided who you are going with for the DP? If so, could I inquire about the price? Thanks, Griff <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0">
Administrator
O2 sensor and spark plugs could loose some longevity. You could actually loose power by running too rich.<p>If all you have done is the exhaust I'm not sure you'd be running rich without an ecu upgrade or some sort of fuel enrichment device. Maybe I missed an earlier thread, if anything you might get on the lean side - you'll be getting the air out quicker but the ecu might not compensate additional fuel quick enough. <p>Tough to say without getting on the dyno and using an air/fuel meter and testing it. I'd recommend doing a dyno run prior to the dp install and then one after, then you'll know how much power you gained...or lost. AND you can test your current air/fuel ratio vs the addition of the dp.<p>The combination of a race dp and tweaking my fuel mixture I was able to get an additional 16 hp at the wheels on my VW. Not too shabby for an 18yr old v-dub. <IMG NAME="icon" SRC="http://********************/smile/emsmile.gif" BORDER="0">
Re: 3 INCH DP" (Griff_33)
Hi, I have a used TME downpipe, and a new catco cat. I have not decided if I'm going to put it on, but I bought mine used on ebay.(350 Shipped)<br><BR><BR>
[Modified by volvos70turbo, 4:20 PM 12-20-2002]
You won that one huh? <IMG NAME="icon" SRC="http://********************/smile/emwink.gif" BORDER="0">
1 - 12 of 12 Posts
