Hey all,
Has anyone ever cleaned the throttle body on a 3.2 XC90? If so, did you follow a write up?
The throttle body is down low, and atop of a crossmember.
I took a look at VIDA and its not really helpful. I'm also not keep on removing the entire intake manifold.
Thank in advance.
S.
2008 XC90 3.2
I've done it. Just take your time and loosen the hose clamps more than you think you need to. It's easiest to get to them from the bottom.
I took the whole intake manifold out and then took the throttle body off. I re-used all the green silicone seals (they were in perfect shape and had great pliability).
