The large tach and small clock are easy to install. You can unscrew the cluster and slide it out to the right so you have room to remove the large clock without having to disconnect the speedometer, etc. The tach only needs one wire hooked to it, and it's already part of the harness behind the cluster (it's white/red with a spade connector already attached). It gets plugged into the lone connector on the bottom half of the tach (the 3 connectors near the top are for the sm. clock). Don't forget the plug that fills the hole from the clock set knob, if you have one.<P>Did you get the small harness for the clock? That powers the clock from the tach. The 3 connectors on the tach are marked 30, 31, and 5x (I know it's 50-something). The 30 goes to + (power), the 31 goes to T (ground), and I believe the 5x goes to the light bulb on the clock.<P>For the volt meter, you'll have to run some wires. From + to a power source switched on at position II, and a wire from T to a good ground connection. There should be a spot behind the center console where there are lots of ground connections terminiating in one spot, so you can add to that with the volt gauge (I haven't looked for it, so I don't know exactly where it is). Most people recommend splicing the wire for the light bulb into the wiring (brown) for the instrument cluster so that the dimmer knob will work on the small gauges too.<P>I use 16 gauge wire and .250" spade connectors. Some light bulbs used really small tabs and I don't know what size they take, but you can solder the wire right onto the connector if you prefer.<P>Here are a couple of pages from the Brickboard archives that should be helpful when installing gauges:<P><A HREF="http://brickboard.com/ARCHIVES/1999JUL/20039137.shtml" TARGET=_blank>How to Install Tachometer in '88 240DL?[200/88]</A><P><A HREF="http://brickboard.com/ARCHIVES/1998NOV/20016764.shtml" TARGET=_blank>small gauges[200/82]</A><P>
