1 - 10 of 10 Posts
Can I put 245/45/17 tires on my '05 S80 without worrying about the tires rubbing?
Thanks,
Todd
will rub.... I Would say thats a little wide.....But, if you maybe run a 30 series sidewall, you could get it to fit.....Then again, you could always get spacers.
Re: (volvo4lif3)
Quote, originally posted by volvo4lif3 »
Why are you wanting to run such a wide tire? How wide will the rim be?
i had 60's front and back on my old GTO. it's fun! although steering, and lane changing can be a challenge...
Re: (volvo4lif3)
I am tired of the tire squeal on corners. The current 215/55/16's just don't have the grip. So I am switching to some 17x7.5 Thor's. Anti-sway bars will probably be next on the list. I love my S80 but I miss the handling of my old Maxima.
Thanks,
Todd
Go with a 235, and get the anti sways like you said... That will improve handling a great deal. Maybe also get some eibach lowering springs....Will def. help. Id say 245 is overkill.....IMHO
Re: (volvo4lif3)
A Maxima handles better than an S80? I highly doubt it. What kind of tires are you running on the S80? That could be your problem right there.
Re: (Majisto)
Quote, originally posted by Majisto »
Equal tires, the Maxima should handle better
As for tires with Thors, you can run 235/45 but you may be happier with 225/45/17 or 225/50 17
A bit taller and a bit narrower but much more livable in the long run and a MUCH better ride
Re: (JRL)
I drove a 2005 Maxima and I picked the S80 over it in part because the torquer steer and under-steer in the Maxima was worse. I thought the Maxima's 5-speed auto was better, but the S80 feels more confident to me.
Re: (Majisto)
"A Maxima handles better than an S80? I highly doubt it. What kind of tires are you running on the S80? That could be your problem right there."
I had a '98 SE for 135k+ miles with 225/50/16's, and I could take a corner at 40 without any squeeling. I know the S80 is heavier, but I think it should just have more grip on the road. Right now it has the stock 215/55/16's.
On a side note the gas milage on my S80 2.5t blows the Maxima away. I hit 525 miles/tank versus the 350 I would get on my Max.
Todd
1 - 10 of 10 Posts
