1 - 10 of 10 Posts
any problem with that size of tires?? i know the turning radio will be less but another comment?. I have that tires Falken Azenis in 245/40 for free.
Re: 245/40 tires on 18" pegasus? (volvos60t5x)
oooo... I don't know about a 245, that's pretty wide. And with a 245, I'd think you'd have to drop to a 35 aspec ratio in order to stop some SERIOUS rubbing. Maybe too wide for the wheel, but definately too tall for the wheel well.
For what it is worth, Falken Azenis run really narrow for a given size based on personal experience (dif car). The good thing about these tires is that they are inexpensive and have a reasonable treadlife. The only reservation I have about these tires is they do not quite offer the grip of summer max performance tires. But free is a big plus.
i.e. section width of 245 40 18= 9.6 (Falken)
section width of 245 40 18= 9.8 (Continental)
There are wider brands than continental
Hope that helps.
Modified by S4evolved at 6:05 PM 5-23-2006
so this tires fit perfect on my car.
Re: (R_Rated)
yes but i have R 18" with R brembo brakes. So we are talking about the same.
Re: (volvos60t5x)
255/35/18 are very close to stock circumference. Only off by just over 1 mph at what should be 60mph.
I would assume those need some spacing not to rub though...
Tirerack has some good pricing on these:
BFGoodrich g-Force T/A KDW 2 (Ultra High Performance Summer)
only $179 each. YR rated.
1 - 10 of 10 Posts
