1 - 8 of 8 Posts
'00 V70<p>Was wondering if there is a consensus on which is better to run on a 17"? Leaning towards the 215 since its at stock height and wouldn't mind a little more sidewall height.<p>thanks
Re: 215/45 vs 205/45 (crash813)
i'm running 215/45/17's on my canistos and i feel that they are perfect for the wheel. 205 may be a bit stretched.
215's are pefect for Gen 1s
1998 V70 T5 with factory m56h; 18t, Green injectors, 50% e85
I'm running 215's with no issues. IPD's website says you can also run 225's on Gen 1s. Not necessarily agreeing; just sayin'. I wouldn't go any less than 215's, and would seriously consider 225's next time, myself.
I agree...215's are the way to go!
I have 225's now and I do get front tire rubbing at full lock on the plastic fender liner- not really a big deal. I will probably get this size again.
I run 215/45/17 on mine.<p>225/45/17 is the closest to the stock 205/55/16 or whatever 15" tire size Volvo used but I've seen a couple of 70s have rubbing with that size and a bunch that do not. <p>215s only throw the speedo off by 1% which is pretty minimal.
1 - 8 of 8 Posts
