1 - 11 of 11 Posts
· Registered
I am just wondering I really need to know. I have to order my tires and i don't want to end up with the wrong ones. Will the 215's looked stretched on the rim i don't want that look, should i move up to 225's???
· Registered
Re: 215/45/17? Is this the correct size for 17" pegs on a 850? (steve850)
Has anyone else done the peg on a 850, if so what tire size did you all use?? I am really in the fog here but i have heard that the 225s will rub and i don't want that. Any advice would help!!
· Registered
Steve,
Sorry I haven't gotten around to taking the pics for you. I have 215/45-17 BF Goodrich KDW2 tires on the Pegs, and they work pefectly fine on my 855R. I also have Eibach camber adjusters up front, and I could only adjust them to -1.5 degrees camber up front while still allowing just a tad for tire sidewall-to-strut clearance with this setup. The only other mod on the 855R is IPD front and rear bars. The car handles very well for a FWD platform -- much more neutral than stock and the negative camber up front REALLY helped.
The 215/45 fits the 8" rim just fine. I'm out of town at the moment, but will be back home shortly. I will get you a picture of the car/tires/wheels by this weekend. Here's the only one I currently have up on the web next to my old 2005 V70R, and you can't see much here:
· Registered
Quote, originally posted by steve850 »
Steve,
I finally got some pics taken of the 8x17 Pegasus wheels with 215/45-17 BFG KDW2 tires. The car handles real nicely for a FWD Volvo wagon. I may have said in another post but it has IPD front and rear sway bars, the Pegs and Eibach camber adjusters. With the Pegs and 215's, I could only adjust the front camber to -1.4 degrees which left just a tad bit of room between the tire sidewall and the front strut, but that 1.4 degrees of negative camber made a huge difference (stock is almost perfectly 0 degrees) in cornering performance.
· Registered
Thanks for the input and the pics. I got 215/45/17 on and they are great looks perfect but are really easy to curb. This car has undergone a total makeover with the wheels, I will update with pics after i buff it out this weekend. Thanks again guys, I seriously love this place.
1 - 11 of 11 Posts
