I picked up a leftover XC60 R-design with all the toys last week. It was $8500.00 off sticker so I could not justify going with the 2019. One thing that seems odd is the auto shut off when stopped. Some times is goes into the stop mode but most of the time it does not even though the car is warmed up etc. Why would this happen?
Depends on battery charge
It’s a feature. Create a profile and turn off start/stop.
Then search for the thread that explains why you can’t turn it off permanently. Should still be on the first page.
Mine works only about 1 of every 25 times I drive the car
I had an MB with start stop a few years back. According to the manual. 7 conditions had to be True for it to work.
So it worked about 20% of the time in summer and 10% in winter.
Generally, if you need heat or high AC, the start stop does not engage. Repeated start/stop also will disengage function, such as in stop and go rush hour conditions.
