1 - 8 of 8 Posts
I have a 2018 XC 90 T5 and the driver seat belt has begun to fray. A case was opened with Volvo no word yet. Has anyone else experienced this?
Where was the belt fraying? The side of the belt (as if it's rubbing against something coming in/out of the B-pillar)? A specific area across the belt face or back that makes it appear fuzzy, has teeth marks like a gear may have made them, or as if someone had scraped it many little times? Is it on any area that normally touches your body when positioned in-place (like around the belt buckle area on your pants), or only an area that first pulls out and generally repositions back in the B-pillar? Or something else?
I ask because on another non-Volvo forum I used to help moderate, I remember multiple seat belt situations and over the years at least one, maybe two, where the physical safety mechanism in the B-pillar was causing the issue and needed to be replaced. It certainly wasn't a common problem with that other brand, and I of course assume your auto has not been in an accident or a situation where the belts auto-tightened (and maybe didn't even then self-release) on you. You're having the problem in the driver's seat so its obviously not caused from holding down a flawed child seat or from an attached animal harness in the back seat (yup, real examples of owner complaints in that other premium brand.) Without a picture, it may help others take a little closer notice on their Volvo belts. Good luck on the repair!
The belt is fraying by the latch so the area around where the belt would slide
Thx for the photo. :) Yup, looks like what I seem to remember was happening on just one side of another guy’s Lexus years ago. IIRC, the internal mechanism in the B-pillar (and a new seat belt) ended-up being replaced for him under warranty.
Update This issue will soon be resolved. Volvo USA authorized replacement A new seat belt has been ordered by the dealer.
Good to hear they are taking care of you, with what is hopefully a more obscure problem. Thx for the update. Enjoy that XC90!
Mine got pinched, at the same level. Substituted at no cost, but I think there is some design problem here. Pull angles were not well calculated...
I also own 2015.5 xc 60 and the seat belt has a roller / guide definitely more thought went into the design.
1 - 8 of 8 Posts
