Discussion Starter #1 (Edited)
2017 XC90 engine sounds rough and missing parts??
I just bought a 2017 XC90 T6 momentum with 27k miles a month ago and the engine is loud during low speeds or around 2k rpm. Is that normal or does anyone else seem to notice it too? Its like a rumble or rattle during initial acceleration and up to around 20 mph then it stops. Since I'm new to Volvo, not sure if I'm just being paranoid or what.
Also looking in engine to figure out noise I noticed this. Are there missing bolts? So confused since I was unable to find any picture or diagram of what is or isn't suppose to be there. Thanks in advance
Ours also has that sound you’re describing too. I just assumed it’s normal.
Discussion Starter #3
did your engine have those screw holes as well? You can locate them right below the support battery, I'm just curious if its just components that are added on depending on the engine configuration. Thanks
