2016 XC90 Ignition Coil Replace
3.8K views 15 replies 8 participants last post by  371083
Hey guys, I'm currently in a tiny town in central U.S. for work. So, today my car's engine light popped on, and I took it to O'Reilly to get it checked with their OBD scanner. Turns out I got this P0301 code, which means there's a misfire in cylinder 1, and they're (the code indicates that) suggesting I should swap out the ignition coil. But, here's the kicker: there's no Volvo dealership within 150 miles of me. So, what's my move here? I've got a couple of ideas, but I'm not sure which way to go:
  1. Just stick with the current ignition coil until I can make time to get to a dealership. But that means I'd be driving around with the engine light on for at least a couple of weeks. I do not know if that is going to cause some damage to the car or even insecurity to the driving.
  2. Or, I could just hit up any old auto repair shop and get the ignition coil replaced with some aftermarket parts. But then, I'm not sure if there's anything stopping those local shops from doing the swap, or if using non-OEM parts might mess up my car somehow?
I'm not sweating the warranty, by the way.
Got any advice?
There could be a number of reasons why the car is indicating a misfire on cylinder 1. I would not recommend blinding replacing the ignition coil. A better approach in your circumstances would be to swap the coil with another cylinder and see if the misfire moves to the other cylinder.
In regards to driving it, I would be interested in the misfire counts, i.e., is it continuously misfiring or is it an occasional misfire. If the motor is continuously misfiring, or if the check engine light is flashing, I would not drive the car.
Thanks for the heads up, the check engine light is always on right now, so maybe that means the motor is continuously misfiring? With that going on, may I ask do you think it's safe to keep driving this car for another 150 miles all the way to the dealership, or is that a bad idea?
Thank you, the check engine light is always on right now, so maybe that means the motor is continuously misfiring? With that going on, may I ask do you think it's safe to keep driving this car for another 150 miles all the way to the dealership, or is that a bad idea?
Steady CEL is not bad - the ecu has detected a few misfires and is letting you know.
Flashing CEL - active and ongoing issue that you should address right away.
if it were me, I’d buy a coil and a plug to have handy since you’re out of town. Like others say, if you swap the coil to another cylinder and the misfire follows, you know that’s the issue.
how many miles on the current plugs and coils?
Counterpoint - I wouldn’t be too scared to drive the 2 hours to the dealer to have them do their analysis either.
Thanks for all the advices that really helped! I think I will try to swap the coil first to see if the misfire swaps too. I dont know the condition of the coils but I did change all the plugs about 5K miles ago.
any time you have a coil code soon-ish after plug replacement it's worth a little visual inspection. it could be unrelated but there could be something that's worked loose (even a spark plug backing out - torque is very low only 18Nm / 13ft-lb)
Thank you! I think I will try to do that before I swap the coils, but I do not have so many experiences about that so maybe there are some loosing but I can not notice that. But 18NM relps, I will try to reckon the torque.
fyi I don't mess around with spark plug torque in aluminum heads anymore. there's too much at stake both from going too low and too high. unfortunately a quality torque wrench is about $100 but I consider it necessary for someone who isn't turning wrenches every day and doesn't have a good feel (like me)
#13 ·
Well, that’s an interesting twist, if the plugs were recently done. I bet it’s a tired coil. Worth checking that the plug is ok in that cylinder.
Even without wrenching experience this is an easy 4cyl to work on. As others have mentioned, aluminum is soft, so don’t overdo any plugs - just snug and a quarter turn is plenty, if you don’t have a torque wrench.
that video posted should be a great reference for the steps.
If you need to order parts there are several Volvo dealers with an online parts department. Makes price comparison easy. I’ve ordered 4 new wheels from several states away because of the price and fast shipping.
