I'm looking at a used 2016 Volvo XC90 T5, but I'm worried about the piston rings issue I've been reading about for 2016 and part of 2017 MY. However, everything I've read refers to the T6. Does anyone know if the T5s also had the same rings that caused this issue? Or could possibly the extra revving of the motor needed for the T5s act as an Italian tune up, keeping the carbon build-up off the rings, so people haven't run into the problem? Or maybe just everyone got the T6s...
Further question - is there any way to see/test if a used car has the poorly designed piston rings and/or the build up (boroscope? compression test?). And if I change the oil every 5K miles or so, maybe add Liqui Moly first and then engine cleaner, do some extra engine revving occasionally, can I avert the issues these piston rings have been causing some people? Other than this possible issue, it seems like the T5 should have less to go wrong on it than the T6 or T8. Thanks for the info.
