1 - 11 of 11 Posts
'06 S60 T5 AWD, '10 S40 RD T5 AWD
Hi everyone,
I'm in the market for a 2015.5 T6 AWD (XC60). I've test driven 2 in the past month and I've noticed that both felt loose in the steering wheel while taking a turn at ~60mph (highway transition turn). Neither vehicle held tight during the turn. The steering wheel had a wave motion, as if it had traction, lost it, and regained it repeatedly. So, if I tried to keep the wheel in 1 position, it wouldn't stay...it would loosely float. The first vehicle had 39k and the last one had 55k miles.
I have an '06 S60 T5 AWD and a '10 S40 T5 RD AWD, neither of which exhibit this behavior.
Any ideas?
TIA,
BJ
Hi everyone,
Any ideas?
TIA,
BJ
LCA bushes.
Particularly the lower rear. But if thats shot, might as well replace em all.
Hard to tell what you are describing but I would be thinking the wheels are out of balance, the cars were out of alignment, or it may just be that you were losing traction.
He means...while on the highway at speed and steering into a long sweeping turn, the car “wonders/deviates” from the direction he is steering. LCAs.
I notice you have a 2015.5 t6 XC60...I'm curious what you think about it mechanically and electronically, both in terms of reliability.
To clarify my description a bit, the vehicle seems to stay on track just fine, but the steering wheel wanders a lot. Too much play. So, if I wanted to hold a turn at higher speed with the steering wheel at the 2 o'clock position, it would float/wander between the 1 o'clock position and the 3 o'clock position. It's a wavy motion, though, not a dramatic or violent shudder or clunk. It certainly does not inspire confidence in a turn.
Tie rods
Reactions: beejam
We had some initial quality issues, about a half dozen things, but after the first two years it's been rock solid. It's a long term keeper for us.
Yeah, that's what I would say but it's a little odd he'd experience the same sensation on test drives with two separate cars that are at pretty low miles for bushing issues - 39k and 56k.
I had this issue a year ago, with the somewhat the same symptoms that you are describing. The steering felt sloppy and not on point. Just by chance I ended up having to replace the rear sway bar links, and surprisingly enough, when I got the car back the steering was all tight again.
1 - 11 of 11 Posts
