581 - 583 of 583 Posts
· Registered
Please provide the attorney's info... I'm interested in participating as well
Even though I traded my 2015.5 V60 and bought a CPO 2019 V90, i still don't like the way Volvo NA handled the "known issue" fortunately the local dealer and their mech staff really did everything they could and continued to do so consonantly replacing rings / spark plugs etc...
You replied to wrong person. @wvrick said he contacted an attorney.
· Registered
Has anyone experience this issue? I have a 2015.5 S60 T5, when accelerating, I get this ticking/clicking noise for about a second or so. And it feels like its losing power. Usually occurs between 3k to 4K rpm. I feel like I don't get that quick torch. Any idea?
A few years late to the conversation, but i figure it may help someone later on. My 2015 Volvo V60 experience the same rattling during acceleration and it turned out to be a small crack in the exhaust manifold. Replacing the manifold in extensive job due to the location and surrounding components. To add insult to injury the exhaust manifold is sold as one unit along with the turbo component. So you will pay anywhere from $1800.00 to $2500.00 USD for the replacement part. Hope this helps. Good luck to you.
· Registered
Just adding additional information for those that haven't heard or seen yet, the engine oil is a likely culprit and should be changed to what Volvo has recommended all along in their owners manuals for "extreme conditions", the RBS0-2AE/SAE 0W20 synthetic oil. Why a thinner oil is recommended for extreme conditions, I don't know as that's different than one would expect, but there's definitely something about it that helps prevent these Low Speed Pre-Ignition occurrences(LSPI). The LSPI is what's causing these knocking noise, it's what is causing the engine to see an abnormal combustion event/Knock and reduce power momentarily as it's potentially hurting itself.
The spark plug change seen earlier on was to spark plug design with less porcelain in the combustion chamber to reduce the possibility of it being broken. This was happening with the earlier designs and potentially causing internal engine damage during instances of LSPI.
This lighter oil likely is reducing the oil vapor that gets consumed or is less ignitable, as oil in the combustion chamber increases the possibility of knocking(it effectively reduces the octane level of your fuel). Those of you who'd like to run 87 octane fuel, likely still can with the new oil, but I will continue to recommend premium because I want my and my customer's engines to last as long as possible with the best possible performance at all times.
In any case, Volvo has finally put out a tech bulletin(TJ34740.3.4) in 4/2020 saying that any car that has had the 2015+ Drive-E/VEP 4 cylinder engine repaired or replaced MUST use the Castrol Edge Professional V 0W-20 synthetic oil. They also say that it's acceptable to use this oil on ALL of these engines, regardless if they've been repaired in the past or not.
All 2021+ cars now ONLY show the RBS0-2AE/SAE 0W20 synthetic oil as being allowed in these engines. They no longer show the A5/B5 5W30 specification oil that was previously considered the "normal" oil for these engines.
If you're having this problem, switch oil, now. It could save your engine, and will give you more power and efficiency if you're experiencing the knocking/clicking sound often.
