541 - 560 of 583 Posts
· Registered
I've been very impressed with Volvo's engine technology (I'm an engineer) of late but as with any new technology there will be issues to work through until they get all the bugs worked out (I have a rule to NEVER buy the first model year of any car for this very reason). But given that, issues like this thread are not specific only to Volvo.
FWIW: I have a '12 Kia Optima SX (2.0L Turbo - Tuned) and we have had similar issues with our GDI engines as well. From the factory, they have switched to colder spark plugs (moving one to two heat ranges colder) as well to keep from 'popping' plugs and destroying engines. The community has through trial/error and talking with factory folks found good answers to keeping our engines from blowing up and on the road.
It comes down to these, fairly common things to do:
1) Run ONLY Top Tier fuel (Exxon, Shell, Costco, etc.) and move from 87 octane to 93 octane. Besides getting better mileage and performance (our ECU's adapt to it), this buys some margin against pre-detonation (i.e., the 'pinging/popping' you hear) and has the better fuel cleaner in it to keep the GDI injectors cleaner.
2) Run with synthetic oil and keep to an oil/filter change interval of NO more than 5K miles. The GDI engines put so much soot and gunk into the oil (especially turbo charged engines with blow-by) and at least on the Optima, these engines are Fuel dilution monsters which tends to break down the oil faster. The oil to use now days is the SN+ oil just coming to market with Dexos1, Gen2 certification if possible with a low NOACK figure. These newer oils are made to combat the LSPI issues and are specific for GDI engines. I run Castrol Edge 0W-40 oil with good results but I have a tuned/modified engine and keep to a 4-5K OCI. My used oil analysis looks good.
3) Install a PCV routed Oil Catch Can and drain it at every oil change. This aftermarket appliance (if you use a really good one) helps keep the GDI intake valves cleaner since they don't get the fuel sprayed on them anymore to keep them clean and keeps 'oil mist' out of the intake which can lead to the bad pre-detonation issues being seen as this lowers the effective octane level of whatever fuel you are running. This is a must if you have a tuned engine (like mine).
4) Run colder spark plugs. Both Kia/Hyundai and Volvo are doing this now as a way to help reduce the possibility of pre-detonation happening from hot spots on the plug tips, etc. I've also switched to hardened 'racing plugs' (aka, HKS M40XL gapped at the factory 0.028" setting) so that even if I were to get a pinging event, my plugs are less likely to break.
5) Every so often, when it is safe to do so and only after you've employed the above tips, go out and do the "Italian Tune-up" on her (drive it hard with WOT events). It really is good for the engine (and your soul). This helps keep the carbon build-up down and "blows the soot out" as my grandfather used to say! Besides, it is mighty fun in these cars!
My car is my daily driver, gets better than OEM gas mileage and I makes over 350HP at the crank in my very zippy fun Optima (now at 74K miles).
Anyway, I hope these developments on other platforms can be helpful for Volvo owners (I'm a former one myself) with the awesome new engines from Volvo (I love the tech in the turbo/supercharged 2.0L engines).
· Registered
Well, I finally had my car to the dealer for it's first visit yesterday, the dealer was scheduling service visits two weeks out unfortunately or it would have been in there sooner. Their answer to the clicking issue was "spark knock", and their advice was to run ONLY premium fuel from a top-tier vendor. No software update or oil change recommendation.
On top of this I did get a battery replacement as the "Low Battery Charge" message was coming up intermittently as well as a broken driver's B-pillar cover ordered on their dime that needed to be replaced. So, it was a worthwhile visit.
Eric
· Registered
Eric do you know if your car had the updated spark plugs installed before you bought it ? I too have purchased the same car as you and my plugs had been changed . Had to have a new valve in gas tank replaced , could not fill past 3/4 tank
· Registered
So you and i also buy a car that says 87 octane is fine but it wont run right with it .
Fine but not recommended. Dealers tend to "deny, deny, deny" before addressing issues that can't be easily replicated by their service department. Not sure why anyone is still surprised by this. I believe if the proper steps are taken to address the noises then 87 octane can still be run.
· Registered
On my 2015.5 XC60 T5 Drive-E I had the same issue. They replaced the spark plugs and since than(approximately 1.5yrs ago) had no issue. It is true though that since, I used only premium gasoline - this was my preference nobody asked me to do it.
Sent from my iPhone
· Registered
So you and i also buy a car that says 87 octane is fine but it wont run right with it . Where i live its about .80 more a gallon . If mine starts doing it i wont be as accepting as you at the dealer .
I think you will find mileage will be better, so its not a "cost" as much as you think. Even my beater listed below gets better mileage on 91
· Registered
1 1/2 years ago , is that when Volvo had the recall for that or was this your 2nd. plug change ?
There wasn't any recall at least here in Canada, I have been 3 or 4 times to the dealer complaining about car symptoms. They finally replaced the spare plugs after explaining them that this remedy was chosen by other dealers.
· Registered
Got our car back this week. Had basically a complete motor rebuild. Pistons, rings, bearings and head rebuild. They told me that there was a lot of carbon build up on the valves so they completely rebuilt the heads. Hopefully we don't have any more issues....
Well our clicking is back. We have probably little less than 20,000 miles on the engine rebuild. Will be dealing with this all over again...
· Registered
Just wondering how many other guys have re-experienced the "Spark-Knock" after Volvo's supposed Fix (of changing sparkplugs and updating software - which i believe is the main work done) ?
I don't want Volvo to just sweep this under the rug, thinking we're going to be quiet about a known manufacturers defect.
I was even thinking of getting a P* until I saw people with them were having the same issue :nono:
· Registered
Damn. I thought I was crazy. I'm both relieved that I'm not the only one to have experienced this issue... and somewhat saddened to know that Volvo's darling new engine has issues...
Granted, I've not had the dreaded "clicking" power-killing noise for several months now -- not since after I had the recalled spark plugs replaced and my ECU updated. One day it just... stopped doing it. I wasn't sure why or how... but I was happy it didn't do it anymore. Now I can charge off on-ramps all I want and not worry about the power dying out on me.
Still, I'd like to know what causes it. I use 87 octane fuel with no issues. And the one time I did try 93 octane to see if it would get rid of the clicking, it didn't do anything it seemed. It worries me to think what other issues might lie beneath the surface just waiting to rear their ugly little heads. :\
· Registered
Low speed pre-ignition is a pretty broad research subject.
There is evidence engine oil is a possible source of it which could mean one of your engine oil changes fixed it.
Hope this helps and happy motoring
· Registered
