1 - 2 of 2 Posts
Hi All,
Does anyone have a surefire technique for getting the halogen headlamp units adjusted just right? I have a set of Philips XtremeVision H11's on order, so figure I'll install the new bulbs and dial in the headlight adjusters all at the same time.
Do you have to readjust the headlights after you swap bulbs each time? Or do they hold their windage/elevation settings pretty well?
This is the way to salvation; http://www.danielsternlighting.com/tech/aim/aim.html
Also you should not have to adjust every time you replace bulbs unless you have gorilla hands and are horribly wrenching the entire housing when you are twisting/untwisting the bulbs.
1 - 2 of 2 Posts
