Discussion Starter #1
hello. well i had my drivers window have issue on auto up.. basically it would go up a bit then go back down, the issue was sporatic and didnt always happen, dealer said the window needed to be reprogrammed, they did it worked a week or so, now it is doing it again... my car is only 3 weeks old and im hoping this is not a sign of bad things to come on quality!.. dealer now says they need to take the door apart and lube the tracks. any one have this issue?
I had the issue, the dealer had to lube all the weather stripping around the window until the window sweepers finally loosened up. Eventually it ceases to happen.
Try pulling window up with your finger on the switch and dont relase the switch for ~10 sec, it fix the same issue on my 08.
On my car the dealer tried both recalibration and lube. On the third visit they changed the motor and lifting mechanics and it have worked perfect since.
