I am going to change to winter tires. I am looking for best jacking points in the middle (front and back) for floor jack.
On my 2010 XC60 there are jacking points between the wheel wells. If you look closely under the car you will see two rounded out areas that allow the jack to contact supporting metal frame area and lift the car safely. Atleast on my '10 this is the case.
If you are not used to jacking European cars note that you are jacking on the seam. You cannot just put the flat jack under there or you will crush the seam. You need an adapter. I have one for my Audi, but found it too deep for the XC60. I made one instead from a hockey puck. Just cut a slot down the middle. Works perfectly. I used it last week to install the snow tires.
