2011 C70 Key Fobs Not Working After Jump-Start
1137 Views 3 Replies 3 Participants Last post by  LRHolland
I had to have a jump-start the other day and since then neither one of my key fobs works. I put new batteries in both with no change.
I'm guessing I need to have them reprogrammed but wanted to check with y'all before I go down that road. It looks like I can't reprogram them myself.
Thanks for the help.
Take a read through this. Should work after you disconnect the negative terminal to the battery/ turn the key to position II and then reconnect, but follow the steps carefully as described.
BD
Reactions: 2
Definitely try this... my roof stopped working after a jump start a few years ago... was kind of resigned to driving a rattly overweight coupe for a bit, but then figured I had nothing much to lose by trying a “hard reboot”... sure enough it did the trick. Good Luck!
Reactions: 1
BD
That was it!! It worked perfectly. Thank you both for the help!
Reactions: 2
