1 - 13 of 13 Posts
Hi All,
I replaced the serpentine belt and water pump (and T-stat) on the 3.2L last weekend. Takes a while, but I found it to be an enjoyable job, like most maintenance chores on this engine. I was hoping to be able to put together a video with better production values, but I got rushed with projects starting to logjam as winter approaches. The result is that I wound up with a very long rambling YouTube video. Hopefully it's useful for someone:
Things I found at 140K miles:
-Belt was in sorry condition
-Water pump was definitely nearing it's end of life.
-Thermostat was broken. 90% functional, but pressure against the head is all that was keeping the insides together.
-PS pump has a center dowel pin that definitely needs (and is supposed to be) replaced. The new water pump comes with a new dowel to line the PS pump up.
-You most definitely need to replace the upper rad hose when doing the T-stat. Mine was very well stuck on the old thermostat.
Cheers,
-Ryan
Reactions: Robusti
Cool to put out a vid. You inspired me to swap out my thermostat which I just finished. Mine was broken also as you described. I’m at 120k.
2010 xc90 3.2 | 2017 Prius V Five
Awesome work! Thanks for making the video!
Thanks!
I hope it helps. The A/C bracket is fairly different on the pre-2011 ones.
I realized only after the fact. that I plugged GearWrenches about 10 different times! Lots of other cringeworthy babbling going on too. I figured that I'd just upload it warts and all just to add to the knowledge base.
-Ryan
Hey @Ryan. Is there some trick to moving the power steering pump far enough away from the water pump? I saw you had yours tucked away under the ABS, but I don't seem to have that much room. I could maybe get those gear wrenches on all the water pump screws, but it's no where near as far away as I saw in your video.
Thanks!
Thanks!
I had to do some gymnastics with the pump to get it underneath the ABS. So much so, it was a little tricky to get the pump back out from under it. One thing I noticed is that the hose to the reservoir is a major player in what you can do with the pump.
If needed, you can gently bend the brake lines a bit out of the way.
-Ryan
Cheers,
-Ryan
Still in the process of replacing mine, but wanted to note that I found both of those items the same on my XC90 @ 160k miles. Spring essentially popped out when I finally got the housing off. I never was able to remove the upper house from that housing. I ended up cutting the hose since I already had a replacement. Waiting on a power steering pump to arrive to continue the fun. :)
-Craig
I wasn't digging the way that the upper and lower rad hoses attach on the ends opposite the radiator. I bought both the upper and lower hoses. I was *glad* that I had the upper hose. The amount of destruction required to remove it from the thermostat was reason enough not to try and replace the lower hose.
-Ryan
Reactions: gezaphoto
This one helped me out!, Bloody knuckles and some dropped bits and sockets and the job is done! 100% agree on the radiator hoses, the old ones are stuck on there.
1 - 13 of 13 Posts
