2009 Cabin Air Filter & other questions
Where is the cabin air filter on a 2009 C70?
Also, is there a way to have the radio turn off when the key is turned off? My radio stays on unless I pull the key out.
And one more question. Where do I find the radio code so I can get XM radio? They want the code.
The cabin air filter is accessed by a plastic panel in center stack area down by the throttle pedal. You have to remove the throttle pedal and I believe a couple of screws that hold the panel in place. the filter then pulls out towards the brake pedal. I just changed mine, it is a real pain! I am not home, but that socket is probably less expensive than buying the metric socket that will work. I forget the size, but if you have large metric size sockets, you may already have what you need. You do need a socket, plus an extension and preferably a flex joint to remove the oil filter cap.
