1 - 2 of 2 Posts
Hello All,
I have read a lot about the Rivets in the door panels failing over time. Currently, my passenger side front door rattles when I play music with bass (dynaudio system). I am thinking about pulling the door panels all around the car and replacing the rivets with screws. My question is, does anyone know what the best screw to use as a replacement?
My rattles were not in the door structure but in the exterior handle mechanism. I moved the lower bass data out of the door and into a sub woofer which helps. I also installed an MLV between the door and the door card.
http://store.secondskinaudio.com/
1 - 2 of 2 Posts
