Hi forum,
I have a 2008 xc90 3.2 AWD 75k miles. yesterday I started my vehicle and shifted into drive and I heard crunching/clunking noise coming from the front end. The Check engine light flickered before I quickly threw it into neutral. The check engine light turned off and I shifted back into drive and drove home with no problem. This morning I started it up and the same thing happened again.
Can anyone tell me what is causing this problem?
If I continue to drive it am I going to cause major expensive damage? (This is my only vehicle and I need it to get to work)
And what I have to do to fix it ( I do most of my own work. Only brakes and oil on this one but I had a 2004 s60 that I did strut assemblies, timing belt etc)
Thanks
Eric
I'd scan it with Vida and see what that cel was. I don't know what it was so I can't tell you if it'd dangerous. That sound could be the axle bolts.. Theres so many threads about them. I don't know how that would trigger the cel. Could be completely unrelated.
Sent from my SHIELD Tablet using Tapatalk
Subframe bushings was my guess before I saw it thew a cel
