1 - 6 of 6 Posts
I got a DSTC Service Required light on my dash this weekend and when I got home I plugged it in and got Code U0136 No Communication with DEM. I checked the AWD Module fuse in the trunk and found that it was blown. I put in a new 10a fuse and as soon as I started the car, it blew that one, too.
I checked resistance for both grounds at the DEM and they are grounded out fine. Does anyone have a next step that I could consider to narrow this down?
Edit 1: Doing some more reading on xemodex and sounds like if the fuse is blowing it's a good sign it's the DEM or pump.
Edit 2: Jumped the pump and the pump turned on, so according to xemodex it is the DEM.
Thanks
Gabe
I looked at the xemodex flow chart again and it says to check the fuse at the rear control module. Where can I find that? I don’t see any mention of that in the user manual. The fuse I was blowing is the AWD System fuse in the fuse panel located under the access panel in the trunk.
nice troubleshooting Gabe. Thanks!
Next step is....? Xemodex can help you?
Well, not quite yet. I at least confirmed the pump is fine, but I didn’t test the power at the REM, but I am not sure where that even is in the car. I cannot find anything on the internet with where it is located.
The Xemodex flow chart is for P2 models which are the previous generation. You have a P3 model.
P3 does not have the REM as shown in the flow chart.
Ughhhh. Thanks. I wish they’d clarify their chart then to remove the 2008-10 XC70 from the applicable vehicles.
So then I was correct that if the pump powers up when I jumped it, but the fuse keeps blowing, then it’s the DEM.
1 - 6 of 6 Posts
