1 - 9 of 9 Posts
Prior to the last oil change my Mom's XC required 1l to get back to the max fill. 3k changing the oil it's gone down to min from probably 3/4 way to the top... That's 1l in 3k miles. Its internal to the engine. PCV sucks in. IC couplings have oil residue on them... Haven't taken the cold side apart. I will next weekend when my sister is back because Mom driving the R scares me. So it's either rings or the turbo IMHO... Coolant looks ok (going to flush soon). No smoke on startup, acceleration, or coasting.
Same brand since purchase last year-- Castrol synthetic 10w30. Might switch to 5w30 for the winter.
At 160k? That would pretty premature in my experience. Wouldn't I see a puff of smoke at startup? Any suggestions on how to check with the head on the car?
Banned
I've seen the seals go earlier than that. If you pull off the intake manifold you can usually get a good peak at them through the intake port.
I'll check .Hopefully it's A) I didn't fill it all the way and it's consumption is .7l/3k B) the turbo...
Maybe a leakdown test and also an Italian tune-up to clear things up? Have you done the rubber glove test? Your PCV could be gummed up.
PCV sucks in. However I have a PCV kit so it might be worth it...
1 - 9 of 9 Posts
