Anyone know if the wheels from a 2006 S40 will fit 2002 S60?
Found the info that bolt pattern is correct but cant find definitive info on the hub bore/offset being do able.
No. Centerbore is different. So unless you want to get CB correcting spacers they won't fit
Is it an issues of the S40 wheels having a larger or smaller center bore? If so then do you know the center bore size of the S40 wheels?
The s40 cb is smaller
