Hello All. I have a very clean 2006 S40 2.4i M56. Right now it has 142,000 miles. Every known S40 issue has been addressed and I have spent lots of hours servicing this car. Recent maintenance/upgrades: OEM TB, accessory belts, coolant, coolant tank, plugs/air filter, temp sensor, crank position sensor, e-focus trans mount, full synethic trans fluid, updated hydraulic mount, new front 02 sensor, newish OEM axles, powered trailer hitch, deunicorned exhaust, stoptech slotted rotors and pads, upgraded rear sway bar, rear axle camber bolts (corrected negative camber issue), new LCAs, new struts and mounts, new tie rods, upgraded speakers, upgraded trim bezels, new Michelin tires, and new Denso alternator. Lots of receipts. Body and paint is in really good shape except the rear bumper which has a couple scrapes and a few minor door dings. Interior has very little wear. Engine is strong and makes no noise and clutch is smooth and has no slip. Great CA car, located in the Sacramento area.
$5500
