I will buy your 850 if it's in perfect working order and also the underseat amp and harness if you're not going to be using it
As for your question:
NO and that's a period.
It will not fit, and it will not match up electronically
Give him the hidden EQ menu to adjust his radio the way he would like it to sound. (Makes a HUGE difference)!!!
Hidden Equalizer. This is for HU613s and 803s only. There is none for 650 and 850s
With the radio switched off, press and hold down [SOURCE], press [Volume] to power
on the radio, and continue to hold down [SOURCE] for at least 5 seconds.
Press [SOURCE] to select a function
Turn [SOURCE] to adjust value
Function Description
FRONT Low1 3 Adjusts the very low frequencies in the front. Valid values
are from 0 to 6. Factory default for S60 is 4.
FRONT Low2 3 Adjusts the low frequencies in the front. Valid values are
FRONT Mid 3 Adjusts the mid frequencies in the front. Valid values are
from 0 to 6. Factory default for S60 is 6.
FRONT High 3 Adjusts the high frequencies in the front. Valid values are
REAR Low 3 Adjusts the low frequencies in the back. Valid values are
REAR Mid 3 Adjusts the mid frequencies in the back. Valid values are
from 0 to 6. Factory default for S60 is 0.
REAR High 3 Adjusts the high frequencies in the back. Valid values are
Ok sure. And thanks. Afaik everything works perfectly. Any way to test it?
Ill let you know when I get it swapped out. Wiring harness and bracket are on the way for my other one.
Sent from my Galaxy s5
