21 - 40 of 601 Posts
· Registered
Anyone who has a late-06, 07, or early-08 of any vehicle which has the TF-80SC, I'd really like to add your production date and transmission serial to the list to see if we can track down a cut-off date for the bad valve bodies. Thanks for those I've received so far.
I was scrolling down to read others' contributions (and slushbrained non-contribution opinions) before doing precisely that:
SR Production date: 1/07 *
Transmission prefix: 06L **
* I've 'forever' believed it to be 1/31/07, but I'm unsure where I'd gotten the day-of-month from; all it says on the B pillar is 1/07
** that's a big part of why I chose this caR, not realizing that late build 07s had been saddled with steel control arms... :mad:
The 06J (from the TNN) means October 2006 (J is the 10th letter...). My 06L means December 2006. So there was a month+ lag between build dates of my transmission and caR. I once checked a 3/[17?]/07 built VR and that seemed to hold true for it also (iirc it was an 07A).
My thoughts on the Volvo 6 speed GT auto trans are that it is pretty stout trans.
I agree; I think the GT is most stout part of the entire caR, not just the drivetrain.
The production date of my 07 SR was around March 2006. I've checked the transmission serial and it does not have the updated valve body.
I did not know that '07s were built so early in 2006. :confused:
· Premium Member
Discussion Starter · #24 · (Edited)
Thank you guys for the additions! Keep them coming. For anyone wondering about production date, the easiest source I've found is the vehicle's CarFax report.
Some cases that seems to be correct, but others there's a huge difference between the letter and the month of production. In the case of the two 2007 V8s on my list, there's a 4 month difference based on your understanding of the system. Also, to add a bit more weird to it, another 2007 V8 has 06M and M is the 13th letter. Maybe they skipped I? These are all the reasons I want to assemble this list so that we can finally get to the bottom of the question.
· Registered
So, dealer charges 4.1 hrs for valve body swap, which means I can do it myself it 12, right?
Does anyone know what all is involved? I've done a valve body swap in a GM 4spd Auto from the 80's and it was more or less a drop in. Does the trans have to come off the car to do it? Possible to do this job on jack stands/ramps without a proper lift?
· Registered
Some have done it themselves but I don't think there is a clear step by step write-up for it
Sent from my XT1575 using Tapatalk
· Registered
At that point I'd be looking for a wet clutch DCT to drop in... And adapt its mechatronic unit.
DCT trans looks good on paper, but I'm just not ready to own one yet. If you look at the Upkeep costs on them, it's crazy. The Mitsubishi one is supposed to have the fluid changed like every 10,000 mi and it's only supposed to be the Mitsubishi spec fluid that is crazy expensive. 6 liters, at $335 in just fluid. All of the other units are similar. I will stick with a normal Torque converter automatic trans. The 6 speed unit in the later R's is a pretty nice trans. Plenty of gears, shifts are quick and with the car switched into Advanced on the 4C it will stay in gear longer, and downshift sooner.
It's a far cry from the lazy slow 4 speed auto trans from the 90's.
I know for sure the trans pan it's self is not in the bottom of the trans like your probably used to. It kinda sits at at a 45 degree angle towards the front of the car. I want to say you have to at least lower the sub frame some to change out the valve body, but can't remember for sure.
It can't be too hard to DIY this VB, I will be doing it my self if mine ever gets bad. I have done a shift kit before on the W4A33 in the DSM, that was not bad at all. Just have to be patient so things don't get broken.
· Registered
I have an '07 VR GT, mfr Nov '06, transmission S/N 06G380280
· Registered
Yup, that's there I'd gotten/remembered the exact date from (thanks), but it'd been so long since I'd looked at it that it took me a while to remember/confirm...
As long as the "huge difference" didn't "go backwards in time", that just means that transmission production continued while vehicle production lagged, and a stockpile of transmissions had built up... So a 4-month lag (dis)proves nothing.
As for that 06M: while it's true that it only takes one counter-example to disprove any theory, it's also true that people sometimes who know that will reject a valid theory based upon a single anomalous data point. (And sometimes some people -- for eg, Judy Wood -- will do so on purpose, in order to disinform...)
Perhaps Aisin can explain that bakers-dozen "06M"...? (?extra production week squeezd in during the normally-off last week of the year?) An '07 R built in February 2007, if there weRe any, might help establish that that there is no letter between (2006) "L" and (2007) "A", and that that (2006) "M" was some sort of one-time anomaly.
If you/we can find a better explanation, good for you (and for all of us). 'til then (or if we find some backwards-in-time units that were definitely not replacements), I'll be sticking with my YYM 'understanding' to 'decode' the date of the AW SNs, and just scratch my head whenever (if) I (ever) see an "M".
PS: maybe that "M" is a one-time 2006 thang, indicating units that had their VB updated/replaced retroactively, late in 2006, after the unit was first assembled, but before it left the AW factory?
· Premium Member
Discussion Starter · #30 ·
Yeah, I'm definitely not trying to disprove your theory. If anything, I'm trying to prove your theory...or any theory. I just want to know the answer. LOL
I suspect what you've presented is accurate. My real goal is to just keep collecting and collecting data points until we finally prove out the answer.
My other goal is to (finally) bring this issue and its overwhelming reach to light. Years ago I thought this was just a few early R's and that I got unlucky. I also previously believed this was just an issue that could "possibly" affect a vehicle before 06J. Years later (and MANY threads read) I've realized this issue affected every unit within multiple model lines for multiple years. There's a lot of vehicles that will, at some point in their life, be affected by this. There's a reason several shops have set themselves up to rebuild and update these units. They've realized the scope and now, we finally are realizing it as well.
Thanks again to all who have submitted data points and KEEP THEM COMING!
· Registered
I would be very interested to know the shops that update these. Been looking for a specialty custom shop.
Sent from my SM-G900V using Tapatalk
· Registered
06 VR here. Manufactured 8/05. Trans is 05G. It has the first symptom of the TNN. It's a flare that really feels like another normal upshift. I like to think I got the rare 7 speed version. ;)
A full fluid change didn't make much of a difference either.
· Moderator
Can the valve body issue cause damage to the transmission or any other component over time, or is it pretty much a benign issue that just affects how the car drives?
I wouldn't think... I am absolutely no transmission expert but valve body issues can come by crap gumming up on the valve ways and restricts fluid flow. Unless something comes loose, clutch packs and such shouldnt be affected
· Premium Member
Discussion Starter · #36 ·
I think I would disagree, but I'm just as much an expert. LOL This problem causes flared shifts, harsh shifts, slamming shifts, neutral conditions which resolve themselves with slamming into gear. I've got to think that takes a toll on the internals of the transmission. It's certainly not operating correctly. I suspect running these with this problem into the period of time where shifts start to get real severe and not replacing the valve body would do internal transmission damage. Once again, though, I'm definitely no expert.
· Moderator
Option #2
There is a VERY advanced method of flushing the Germans use but I don't know if it's state side. They actually run the car on a dyno and have a machine that injects and extracts the fluid as the vehicle is moving under load. It's very wild stuff and works extremely well, it's supposed to prevent all the horrors that come with a normal power flush machine.
Personally if you have under 80k, drain an fill 3-4 times then repeat one cycle every 10k and your fine. I've learned from my Xc70 (Aw55) how to properly prevent this awful thing from happening. The trans was definitely slapping gears at 65k, once I did a full 12 quart drain an fill it worked it's way out completely by 70k. I have had zero issue's since then, I did another drain an fill at 85k (A simple 3 quart replace) and the fluid was almost perfect. Again now at almost 100k, I'm going to do it again and keep repeating the process. 20$ and 1 hour of my time + a small mess is worth it to stop a MASSIVE failure.
I have the never had valve body replaced... ;)
EDIT! The Tim Eckhart Method.
www.automatic-transmission-fluid-exchange.com
I FOUND IT! ON AN S60 LOL!
Here are the original video's!
I think it's just the english version.
· Premium Member
Discussion Starter · #40 ·
That's great info and would, no doubt, do an excellent job of maintaining an otherwise fully-functional transmission (AW55). However, in the case of the TF-80SC before 06J, this cannot prevent and eliminate the issue because the issue is not fluid related. The issue is that the valve body was designed incorrectly. I suspect this may help to extend the life of the valve body, but it won't correct the problem.
