1 - 2 of 2 Posts
2005 V70R Magic Blue/ Nordkap 130K Extensive Maintenance.
For sale is my Magic Blue/ Nordkap 2005 V70R with 130k miles. We are located in Windsor Ontario, right across the border from Detroit, Michigan. I am the second owner and have all my paperwork from our date of purchase. Original owner's warranty work is also documented. All work under extended warranty performed at Performance Volvo of Windsor. All work performed after that done by Volvo tech from above-mentioned dealership. Only mod is IPD Track Spec sway bars.
Interior is in excellent condition. Seats have no tears, broken stitching etc. The AC is ice cold, heater is hot, no dash lights. Original textile floor mats and Volvo rubber winter mats included.
Exterior is in very good condition, only flaw (above normal wear for car this age) is a small dent from one of the uncaring in a parking lot and a light scratch on the rear edge of the rear drivers' side door. (touched up). The front bumper has stone chips, but paint is in extremely good condition, Windows are lightly tinted.
Factory installed options: This is a Canadian car, I believe all options including full safety glass, and trailer hitch (never used), are installed. It does not have park assist, subwoofer or navigation.
Dealer installed option: iMIV LE iPod adapter
Major services performed during my ownership:
- Angle Gear, sleeve and all seals done at 68k mi
- New Clutch, slave cyl. when slave cylinder started to leak at 70K mi
- Timing belt/ water pump at 100k / _______mi
- AOD pump rebuilt at 128k / _____mi
- All wheel bearings, and E-brake at 100k / _____mi
- Upper Engine/Lower trans mounts at 100k/ ________ mi
- OEM Monroe 4C struts/springs/spring mounts/isolators, lower control arm bushings at 120k/ _______ mi
- Conti DWS and brakes at 125k/ __________ mi
Other parts:
- New rad -2011
- OEM coil packs
- IPD Track Spec Sway Bars
- Michelin X-ICE 2 snow tires mounted on original 17" Pegs. Second set of pegs new '09, summer only, like new.
Maintenance:
ALL fluids flushed @50K mi intervals
Brakes bled every 2 years
Oil changes-Pennzoil Platinum, only every 3k mi.
NOTE: Vehicle odometer is kms, all data above converted to miles - current mileage = 209,000km (130,000miles)
Asking $12,000 USD for the car. The ONLY reason for sale, is that our son was to buy this after I did the shocks/brakes
/tires etc. After I bought my new car, he was enticed to buy my wife’s CTS coupe. The car is clear title.
Contact for more information by email [email protected]
1 - 2 of 2 Posts
