Hey,
Can anyone lead me in the right direction on this one???...
My 2005 T5 V50's telescoping steering column will not hold locked in the telescoped position. It drifts in towards the dash.
Is there a tensioner or some sort of locking device that you are aware of that can be changed or adjusted? Where do I start to get into the column to explore??
Yep, all stupid questions and answers aside... I am locking it. It has slowly, over time, loosened off to the point where driving down a bumpy road will vibrate the steering wheel back towards the dash. I can pull it back out with little effort.
I presume it's design releases it in an emergency as a safety function, however I think mine is now too loose.
I'll take it appart and investigate, was just looking to see if anyone had it apart before.
Cheers,
S
Haven't looked at the S40 but on my 850 there was a simple adjustment. Had the same problem, slid way too easily. A couple turns of a screw and all was well.
Wow I get to answer one for a change. Very simple. Cover under column is held on with 3 torx screws, remove them, no need to remove cover just lower and a 13mm nylock nut is exposed on the left side of column, tighten just a little and test.
I had this problem for months, I would hit the brakes hard and the column would go down and scare the ---- out of me.
If you're still around, thanks a bunch for this. I've been having this problem for years. I resolved it within a few minutes last night, after reading this post.
