When I pull the stalk in to switch on the high beams, nothing happens. Neither high beam turns on, nor does the high beam indicator light up on the dash. Both fuses are fine. O'Reilly suggests it is a faulty relay, but as far as I can tell, the relay is built into the CEM.
I've tested both bulbs and they appear to be fine. I tested the socket into which the bulbs plug into and they do not appear to be getting voltage.
Do I need a new stalk? Is there, in fact, a dedicated relay for this? Thanks in advance.
