Hi All,
I recently acquired a 2005 S60R and the rear port works, front port does not. The previous owner said he never had an issue.
I checked under the dash at fuse 11 and it has not popped.
Anyone have this issue? If so, what is the remedy?
Thanks!
Hi All,
Thanks!
Mine has never worked along with my radio and power passenger seat. My CEM is bad and i have to replace it at some point to get them to work again. I would also pull the center stack and just make sure it didn't come unplugged. More experienced members will have some better recommendations but i would check the connection first.
You wouldn't need to pull apart the center console. Pull the fuse and you should be able to use an ohm meter to check continuity between the positive of the socket, back to one side of the fuse holder.
Remember one side of the fuse slot will be +12v and the other side runs to the socket. You can also check that one side of the socket is ground.
